Is there a way to add a DEM file to a surface with Dynamo?
As it says in the subject line, I’m looking for a way to add a DEM file to a surface using dynamo. My attempts at using the api documentation to write python code in Dynamo has been…discouraging…and I was hoping a tool already exists or someone could give me some pointers with the code. Any help would be appreciated!
Hi @rpriceAZEG6,
Are you looking to create a grid surface or TIN surface from the DEM?
A TIN surface from the DEM
@zachri.jensen Any luck with this one?
Hi
See this and need some changes
It is recommended to add a data clip boundary first to the Surface before adding one or more DEM files.
Never tried to use it before
Thanks for this recommendation
@hosneyalaa You show a screenshot of the SurfaceDefinitionDEMFilesMembers page but I’m having a hard time locating that on the website. Could you post a link to that page?
https://help.autodesk.com/view/CIV3D/2022/ENU/?guid=9d30e072-4ea5-e414-9a4d-82f235209df3
I’ve attempted to write Python code for this operation but I’ve run into a wall.
I think there is something wrong with the filename. I guess \ must be / or \ in Python. So use:
C:\path to file\filename.tif
or
C:/path to file/filename.tif
Does that help?
I would just use a file path node and then have the path as an input to the Python node. Then you don’t have to worry about typos.
Success! Correcting the code with / instead of \ allows my to add a DEM to a surface!
@zachri.jensen Wanted to leave a special callout to you and your recent episode with office hours. Before watching the class all I could accomplish with the API was crashing C3D. The code above was made using the principles y’all teach in the episode (linked below):
Glad to hear it! Nice work :muscle:
Can someone post the python code for civil 3D 2023 version, this code did not work.
Anyone using this still and can share the file or feedback?
Can you clip before creating the Civil 3D surface?
I have plans to add such a node to my package The Civil Nodes. Maybe next week :slight_smile:
The latest version of The Civil Nodes package can add DEM files to a Tin Surface.
