Rebuild Surface in Civil 3D Using Python
Hello everyone,
I’m new to learning Python for Civil 3D and Dynamo, and I’m trying to create a Python script that automatically rebuilds a surface in Civil 3D. However, I’m running into an issue, and the script is not working as expected.
Here’s the code I’ve written so far:
import sys
clr.AddReference(‘AcMgd’)
clr.AddReference(‘AcCoreMgd’)
clr.AddReference(‘AcDbMgd’)
clr.AddReference(‘AecBaseMgd’)
clr.AddReference(‘AecPropDataMgd’)
clr.AddReference(‘AeccDbMgd’)
clr.AddReference(‘AutoCADNodes’)
from Autodesk.AutoCAD.DynamoNodes import *
doc = Application.DocumentManager.MdiActiveDocument
ed = doc.Editor
dataEnteringNode = IN
surfaceName = ‘1’
surface = None
SurfaceCollection = IN[0]
if SurfaceCollection == surfaceName:
    surface = s
    break
Ensure we found the surface
#if surface is None:#
raise Exception(f"Surface with name ‘{surfaceName}’ not found.")#
Rebuild the surface
try:
surface.Rebuild()
print(f"Surface ‘{surfaceName}’ has been successfully rebuilt.“)
except Exception as e:
print(f"Error while rebuilding surface: {str(e)}”)
Add dynamo file
what is your issue? could you reformat the post to see the formatted code?
Also as @hosneyalaa suggested the best would be to share the dynamo file, if you are able to.
I’m very sorry but because I’m a new member here , it is not allowed for me to upload files .
So i uploaded the dynamo file on We Transfer , here is the link
try
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
from System.Collections.Generic import Dictionary
cdoc = CivilApplication.ActiveDocument
def get_sample_line_info(SurfaceCollection , surfaceName):
	global adoc
	global cdoc
	output = []
	if not SurfaceCollection:
		return
	if not isinstance(SurfaceCollection, list):
		sampleLines = [SurfaceCollection]
	with adoc.LockDocument():
	    with adoc.Database as db:
				for Surfac in SurfaceCollection:
					vals = []
					sampleLineId = Surfac.InternalObjectId
					objSurfac = t.GetObject(sampleLineId, OpenMode.ForRead)
					if objSurfac == surfaceName:
						objSurfac.Rebuild()
				t.Commit()
	return objSurfac
OUT = get_sample_line_info(IN[0], IN[1] )
I’m really thankful , but unfortunately this code is not rebuilding the surface
REPLACE
WITH
objSurfac = t.GetObject(sampleLineId, OpenMode.ForWrite)
