RebarHookOrientation how to understand left right
Hi all,
I still have some ambiguities and haven’t yet developed a consistent understanding of the RebarHookOrientation rule. There’s something that keeps tripping me up and preventing me from fully grasping the logic behind RebarHookOrientation.
In the example below, I tried to understand the hook orientation logic from the rebar shape “23” by exploring different cases: first, I edited the shape by reversing its direction; then I reversed its hooks; and finally, I attempted to recreate the original shape “23” by using the standard shape “00” and by applying the same parameters. However, I wasn’t able to reproduce it successfully, which has left me even more confused!?
here my used code:
import sys
import System
from System.Collections.Generic import IList, List
clr.AddReference('RevitAPI')
top_bar_type = UnwrapElement(IN[0])
hook_type = UnwrapElement(IN[1])
cover = 0.05/0.3048
# Collect beams
all_beams = FilteredElementCollector(doc)\
    .OfCategory(BuiltInCategory.OST_StructuralFraming)\
    .WhereElementIsNotElementType()\
    .ToElements()
beam = all_beams[0]
curve = beam.Location.Curve
top_curve = Line.CreateBound(curve.GetEndPoint(1), curve.GetEndPoint(0))
width = beam.Symbol.LookupParameter("b").AsDouble()
top_curve = top_curve.CreateTransformed(Transform.CreateTranslation(XYZ.BasisY.Multiply(width/2 - cover)))
with Transaction(doc, "create rebars") as t:
    t.Start()
    top_rebar_curv = List[Curve]()
    top_rebar_curv.Add(top_curve)
    top_rebar = Rebar.CreateFromCurves(
        doc, RebarStyle.Standard,
        top_bar_type, hook_type, hook_type,
        beam, XYZ(0,-1,0), top_rebar_curv,
        RebarHookOrientation.Left, RebarHookOrientation.Right,
        True, True
    top_rebar.GetShapeDrivenAccessor().SetLayoutAsFixedNumber(3, width-2*cover, True, True, True)
    t.Commit()
OUT = top_rebar, top_curve.ToProtoType()
Any further details or explanations that could help solidify my understanding would be greatly appreciated.
Thanks.
Everything looks correct other than the fact that the your code should have set the starting hook orientation to Left (when it’s reading and showing Right). What happens if you use SetHookOrientation to force the orientation again?
