Rebar's hooks in circular wall won't be oriented to the right
Hi All,
my rebars hooks won’t to be oriented to the right , they still fixed to the left…any idea to solve this issue?
radial_rebar.dyn (70.4 KB)
voile_circulaire.rvt (2.2 MB)
I get the same issue here Wrong rebar hook orientation
Thanks.
Hey :slight_smile:
If its the same topic, its better to bump your original post that doesnt have a working solution yet instead of making a new one with the same issue.
you searched on the side of the rebarhookorientation (left/right)
you put the same value at the beginning and at the end
Cordially
christian.stan
@christian.stan
Did you take a look to my dynamo script?
If you change hooks orientation to the right side ,they still oriented to the left!!! …this issue is due to curves vectors orientation or to another thing?
Thanks.
if i’m trying to answer, it’s that i’ve searched a bit, i’m not a rebar specialist under revit, it’s a proposal that tries to get you going (sometimes it works, sometimes it doesn’t )
Cordially
christian.stan
@Garbage_Collector
I work in another project and my problem is a little diferent (in this case my hooks are in the same direction and they won’t rotate but in the other post only one hook won’t to rotate).
