Rebar with dynamo script for stirrups beam
Hello all
Can anyone help me how to create stirrups for beam with dynamo script
I try and can’t
The places are in the wrong direction
I hope anyone help me i need it more and thx
This forum tends to work on a you try we try basis, so if we can see what you have tried that is olacing them in the wrong place then you sre far more likely to have success here.
Look at this
Unfortunately, I don’t understand Python I will copy the script if you can help me
In the step of drawing the rectangle, I changed the width with the length, and the purpose was to draw the section of the stirrups in the other direction. Is there another solution instead of changing the length to the width? When drawing the reinforcement, he draws the stirrups lock at the bottom. I want to make him draw it at the top Is there a solution? Please help I apologize for my weakness in the English language
I’m not able To help you
You can search the site and find a solution close to it There are experts here To help you before, you should add the dynamo file The Revit file is an example
Ahh thank you
I solve it
And anyone need the script i can send no problem for me
good
Some words have a good effect
