RebarStyle("StirrupTie") - not accepted for creating a rebar from RebarFromCurve in the api
I am trying to create a rebar from the revit api using RebarFromCurve method.
As I enter the RebarStyle as a StirrupTie (node from the Structural Design package) I recieve the following error: Warning: IronPythonEvaluator.EvaluateIronPythonScript operation failed.
File “”, line 40, in
TypeError: expected RebarStyle, got str
Thing is I am not entering a string…
Next I tried entering the element directly from the API - RebarStyle.StirrupTie but I still get the same warning.
clr.AddReference('RevitAPI')
clr.AddReference('System')
curves = UnwrapElement(IN[0])
rebarStyle = UnwrapElement(IN[1])
rebarType = UnwrapElement(IN[2])
startHookType = UnwrapElement(IN[3])
endHookType = UnwrapElement(IN[3])
startHookOrientation = UnwrapElement(IN[4])
endHookOrientation = UnwrapElement(IN[4])
host = UnwrapElement(IN[5])
vector = UnwrapElement(IN[6])
newRebar = Rebar.CreateFromCurves(doc,rebarStyle,RebarStyle.StirrupTie,startHookType,endHookType,host,vector,curves,startHookOrientation,endHookOrientation,True,True)
OUT = newRebar
Anyone?
hello,
the error indicates that you probably passed the type name instead of the type itself at node input
You have some examples here
https://forum.dynamobim.com/search?expanded=true&q=Rebar.CreateFromCurves%20%20tags:python%20before:2022-01-10
Thanks for the reference but none of them refer to my issue. Plus, most of the examples don’t have any responses…
Btw I actually managed to get passed that, I changed the input to RebarStyle.StirrupTie and it works.
But I now have an issue that I am not managing to get passed with the following warning:
TypeError: expected XYZ, got List[object]
I am changed the input to “vector = IN[6].ToXyz()” but I am still getting the message that “list object has no attribute to ToXyz”. Any reason why it would read the Vector object as a List object?
Any ideas?
try :
vector = IN[6][0].ToXyz() should solve this error
This is the message that I get when implementing this change:
Warning: AttributeError : ‘list’ object has no attribute ‘ToXyz’ [’ File “”, line 34, in \n’]
Don’t know why but it worked when I flatten the list. Weird thing is that I used the flatten list previously and it didn’t work then but now it is working…
But now pops up a different problem :slight_smile:. I’ll just have to take care of that now.
I’ll update on further issues if I can’t solve them. Thanks!
So my next problem is with the code for the method “CreateFromCurves”, here is the warning that I get:
“Warning: TypeError : No method matches given arguments for CreateFromCurves: (<class ‘Autodesk.Revit.DB.Document’>, <class ‘int’>, <class ‘NoneType’>, <class ‘Autodesk.Revit.DB.Structure.RebarHookType’>, <class ‘Autodesk.Revit.DB.Structure.RebarHookType’>, <class ‘Autodesk.Revit.DB.FamilyInstance’>, <class ‘Autodesk.Revit.DB.XYZ’>, <class ‘str’>, <class ‘str’>, <class ‘list’>, <class ‘bool’>, <class ‘bool’>) [’ File “”, line 40, in \n’]”
Can it be that it doesn’t recognize the method or the inputs?
rebarType = IN[2]
hookType = UnwrapElement(IN[3])
hookOrientation = UnwrapElement(IN[4])
newRebar = Rebar.CreateFromCurves(doc, rebarStyle, hookType, hookType, host, vector, hookOrientation, hookOrientation, hookOrientation, True, True)
OUT = newRebar
You forgot the list of curves in the arguments of your method. (which must be converted with “ToRevitType()” and cast it into an .Net List[Curve] Collection)
As you have changed Python engine, it would be wise to create a new topic
Sure thing I’ll create a new post.
Just a couple of question:
  1. All the errors are to do with the casting of the curves to .net?
  2. How would I cast the list to a .net list?
No
an example
import sys
import System
#import Revit API
#import net library
listDB_Curves = List[DB.Curve](myPythonlistOfCurves)
