I try to write python scripts for stirrup create by curves and shape but got Unexpected indent warning
These are my scripts
import sys
# Import Revit Services
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import Curve as RCurve
from Revit.Elements import *
import System
import System.Array
#get the document
#Function
def stirrup(x1, y1, b, h, cover, shape, type, host, norm):
    nx1 = x1 - (b / 2) + cover
    nx2 = x1 + (b / 2) - cover
    ny1 = y1 - (h / 2) + cover
    ny2 = y1 + (h / 2) - cover
    nz1 = 0
    point_list = []
    outLine = []
	    #Create Point
	    pt1 = XYZ(nx1, ny1, nz1)
	    pt2 = XYZ(nx2, ny1, nz1)
	    pt3 = XYZ(nx2, ny2, nz1)
	    pt4 = XYZ(nx1, ny2, nz1)
	    #Create Point List
	    point_list.append(pt1)
	    point_list.append(pt2)
	    point_list.append(pt3)
	    point_list.append(pt4)
	    #Use Point List Create PolyCurves
	    polycurve1 = PolyCurve.ByPoints(point_list, true)
	    outLine.append(polycurve1)
	    #Change from PolyCurves to Curves
	    curve1 = PolyCurve.Curves(polycurve1)
        #Getting hook parameter from rebar type family
	    hook_at_start_parameter = rebartype.LookupParameter("Hook At Start")
	    hooks = hook_at_start_parameter.AsString()
	    hook_at_end_parameter = rebartype.LookupParameter("Hook At End")
	    hooke = hook_at_end_parameter.AsString()
	    #Get Family by name
	    shook = UnWrapElement(Family.ByName(hooks))
	    ehook = UnWrapElement(Family.ByName(hooke))
	    #Start Transaction
	    #Create Stirrup base on curves and shape
	    #Function : Rebar.CreateFromCurvesAndShape(Document, RebarShape, RebarBarType, RebarHookType (Start Hook), RebarHookType (End Hook), Element, XYZ (norm), IList<Curves>, RebarHookOrientation (Start), RebarHookOrientation (End))
	    stirrup1 = Rebar.CreateFromCurvesAndShape(doc, shape, type, shook, ehook, host, norm, curve1, left, left)
	    stirrup_list.append(stirrup1)
	    #End
    return stirrup_list
pointx = IN[0]
pointy = IN[1]
width = IN[2]
height = IN[3]
covering = IN[4]
rebarshape = UnwrapElement(IN[5])
rebartype = UnwrapElement(IN[6])
element = UnwrapElement(IN[7])
vector = IN[8]
stirrup_list = []
result = stirrup(pointx[0], pointy[0], width[0], height[0], covering[0], rebarshape[0], rebartype[0], element[0], vector[0])
OUT = stirrup_list
When I run these code it show this error unexpected indent and I can’t find the cause of this error.
This function I try to get RebarHookType (Start Hook) and RebarHookType (End Hook) information from rebar type family, am I using the right scripts? I mean in my rebar type family already have hook type and I try to get that name in form of string and use this name to later get hook type family. For Hook Orientation only accept input is either left or right, can I just type it directly like this?
no matter what I try it still show Unexpected indent error.
To find these I often find the most likely way is to comment out every line from bottom to top, excepting the ‘out’ line, until you stop getting the warning. Running your code periodically as you write it also helps prevent them as you’ll know which line has the error.
Thank you for advise, I hv found my error. It actually pretty simple but I just cant detect it in a chunk pile of code together.
Hi, I exactly give these 10 overloads (doc, shape, type, shook, ehook, host, norm, curve1, left, left) in Rebar.CreateFromCurvesAndShape() but I am getting null. I dont know why is that happening can anybody help me
