I’m dealing with an issue I don’t know how to fix. I have a script that puts the rebar tags in a defined location. If I run my script the first time I get the rebar tags created but not in the location that I wanted.
¿What do you mean? If I run my script once, but not closing Dynamo (so the instance is still open) and I run for second time, I get the desired location.
If I run it once, close Dynamo and open it, I run it again I get the same result as the first time. The wrong location.
I have now the same behavior like you.
The position of the tags is changing to the desired location after i run the script the second time.
Sorry…in the moment, i can’t explain why…
It is advisable to get the view plane and get a geometry by intersection with the host element or the rebar to obtain points on those geometry. Those point at any point will be within the view.
