Rebar along path
Hey everyone,
I need to reinforce complex shape that is not covered by standard Revit 2026 tools:
So I decided to place one instance at the beginning of the instance and the multiply it by dynamo.
The problem is that when i use node “Select model element” then I can not find a way to copy the rebar instance… It is not standard family and I can not manage it.
Do you have any ideas? Thanks.
This feels like something f which could be populated by the standard tools… can’t confirm or help without the model (or a similarly failing one) though.
Hi Jacob!
Unfortunately we can not handle it by standard tools. Infrastructure elements are in multiple curves and spirals and this is making a lot of issues.
  1. Varying rebar set is kind of useful but it is perpendicular always to the start plane and in the end we are getting something like that:
  2. Path or surface reinforcement needs surfaces to be connected but in most cases this is imposible:
  3. I can not use array due to complex alignment.
I wish it was possible by standard tools but Revit is not for complex infrastructure(for now)…
So I decided just to draw one bar at beginning of the element and then multiply it by dynamo perpendicular to any edge. I made everything else but I can not manage to copy the element…
Model in GoogleDrive: https://drive.google.com/file/d/1Ei2GL8sMunV3RtT4Z7F3Xl64s6JUS9Xc/view?usp=sharing
I found kind of solution…
  1. I did not manage to work with ElementTransformUtils.CopyElement and Rebar type…
  2. I put the bars in model group and then I was able to copy it. Its too slow and complicated idk if its the only way.
