Hi everyone, I made this algorithm to read column distances in x and y directions. However it works only if columns are perfectly oriented in x and y direction, but it should work even if they are rotated compared to x & y.
Here you are my original structure in revit and my dynamo definition. So i wuold like to have same results (distances in main directions) if my structure is rotated, like in the image below:
Hi, are you comparing the x and y locations of the columns by using the coordinates in Dynamo or revit? You may need to translate them to your project coordinate system if using the later. Not at the PC till tmw, will update with an example then (but feel free to chime in anyone at their desk)
Don’t know if i understood what you mean, but i don’t think that the problem is in using revit or dynamo coordinate system, because i need to maintain the building rotation, even if it’s rotated in the project coordinate system. So i need to read distances between columns in the two main directions of the building plan.
I’m sorry if i can’t explainit better.
Anyway here it is my dynamo graph screenshot @jacob.small.
I was thinking you would need transform the location points into a rotated coordinate system so that the X and Y were able to be read consistently. Is this clearer?
