Hi …
Looks like a conflict between AutoCAD Database Services and Civil Database Services.
The line
surf = id.GetObject(OpenMode.ForRead)
to access the Surface object by it’s object id is not correct, results in error …
NullReferenceException : Object reference not set to an instance of an object.
at Autodesk.AutoCAD.DatabaseServices.ObjectId.GetObject(OpenMode mode)
with adoc.LockDocument():
with Database(False, True) as db:
db.ReadDwgFile(path, FileShare.ReadWrite, False, "")
cdoc = CivilDocument.GetCivilDocument(db)
sids = cdoc.GetSurfaceIds()
for id in sids:
just-surf.dyn (13.9 KB)
1.DWG (1.6 MB)
Locking the Autocad document is not required when you are side loading a DWG as the database.
You’re not inside a transaction - this is a requirement to get objects, after loading the DWG start the transaction manager.
using the id.GetObject()
method outside of a transaction will not be very stable. It’s safer to use t.GetObject(id, OpenMode.ForRead)
inside the transaction.
Is it possible that there are no surface ids? You could check with if sids.Count > 0:
And, as always, commit your transaction at the end
I was hoping to avoid using a transaction - but … it’s not possible … will redo the code today and try again … Thx Mike - your input is always highly appreciated.
Thx Mike … this is working…
import os
import sys
from System.IO import FileShare
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
fset = IN[0]
o = []
def dwgtask (path):
if not os.path.exists(path):
return False
if adoc is None:
return False
for id in sids:
surf = t.GetObject(id,OpenMode.ForRead)
o.append([path,surf.Name])
t.Commit()
db.CloseInput(True)
HostApplicationServices.WorkingDatabase = adoc.Database
return True
for f in fset:
if not os.path.exists(f):
continue
dwgtask(f)
OUT = o
