First - a huge embarrassing apology - the previous topic I posted
(Application alias and DocumentCollectionExtension) … : (
I realized the simple errors the very next day as soon as I got to the office - sorry for wasting posts - it should be deleted.
This topic post explains why I reverted to opening with Document Manager.
We have a folder containing DWG files with Alignment DREFs. They need Surface Profiles and Profile Views.
When I batch process using ReadDwgFile the resulting surface profiles do not have elevations.
But when I batch process using DocumentManager.Open, the results are correct.
What did I miss?
Thanks for your extended patience and guidance.
K.
Here’s the 2 scripts…
import os
import sys
from System.IO import FileShare
from traceback import format_exc
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
tbl = IN[0]
ciset = IN[1] # # # 0 - file name col, 1 - alignment name col, 2 - MSX col, 3 - MSY col
tf = IN[2]
sp = IN[3] # # # 0 = surface name, 1 = layer name, 2 = style name, 3 = label set name
def dwgtask (path,px,py,aname):
if not os.path.exists(path):
return False
if adoc is None:
return False
da = None
with adoc.LockDocument():
with Database(False, True) as db:
db.ReadDwgFile(path, FileShare.ReadWrite, False, "")
HostApplicationServices.WorkingDatabase = db
cdoc = CivilDocument.GetCivilDocument(db)
pv = cdoc.Styles.ProfileViewStyles.get_Item(sp[4])
bs = cdoc.Styles.ProfileViewBandSetStyles.get_Item(sp[5])
aset = cdoc.GetAlignmentIds()
for id in aset:
da = t.GetObject(id,OpenMode.ForWrite)
if da.Name == aname:
try:
spid = Profile.CreateFromSurface(aname + "-EG",cdoc,aname,sp[0],sp[1],sp[2],sp[3])
pvid = ProfileView.Create(id, Point3d( px, py, 0.0), aname, bs, pv)
except:
da = format_exc()
break
t.Commit()
db.SaveAs(path, DwgVersion.Current)
HostApplicationServices.WorkingDatabase = adoc.Database
return True
for i in range(1, len(tbl)):
fn = tbl[i][ciset[0]]
if fn:
nfp = tf + '\\' + fn + '.DWG'
if os.path.exists(nfp):
dwgtask(nfp,tbl[i][ciset[2]],tbl[i][ciset[3]],tbl[i][ciset[1]])
Application.ShowAlertDialog('Script run completed.')
OUT = 0
import os
import sys
from Autodesk.AutoCAD.ApplicationServices import DocumentCollectionExtension
tbl = IN[0]
tf = IN[2]
elog = []
return False
adoc = DocumentCollectionExtension.Open(dm, path, False)
dm.CurrentDocument = adoc
if adoc is None:
return False
da = None
with adoc.Database as db:
civdoc = CivilDocument.GetCivilDocument(db)
pv = civdoc.Styles.ProfileViewStyles.get_Item(sp[4])
bs = civdoc.Styles.ProfileViewBandSetStyles.get_Item(sp[5])
aset = civdoc.GetAlignmentIds()
for id in aset:
try:
spid = Profile.CreateFromSurface(aname + "-EG",civdoc,aname,sp[0],sp[1],sp[2],sp[3])
except:
elog.append([path,aname,format_exc()])
break
t.Commit()
if adoc:
DocumentExtension.CloseAndSave(adoc,path)
return True
dm = Application.DocumentManager
if fn:
OUT = elog
road-model-add-pvs-open.dyn (20.5 KB)
road-model-add-pvs-side.dyn (20.5 KB)
road-design-set.xlsx (15.7 KB)
R10M-R01.DWG (1.6 MB)
R16M-R01.DWG (1.6 MB)
R25M-R01.DWG (1.6 MB)
0525.58.00.Alignment Baseplan.dwg (1.2 MB)
0525.58.00.GZA.02.NGL Ext 8.dwg (1.9 MB)
