.Net WblockCloneObjects please help
Hi …
This portion of code with C# does the copy between databases without error …
var mapping = new IdMapping();
using (var sourceDb = new Database(false, true))
    sourceDb.ReadDwgFile(xrpath, FileOpenMode.OpenForReadAndAllShare, true, "");
    ObjectId xrMsId = SymbolUtilityServices.GetBlockModelSpaceId(sourceDb);
    var ids = new ObjectIdCollection();
    using (var tr = new OpenCloseTransaction())
        BlockTableRecord xrMS = (BlockTableRecord)tr.GetObject(xrMsId, OpenMode.ForWrite);
        foreach (ObjectId id in xrMS)
            Entity ent = (Entity)tr.GetObject(id, OpenMode.ForWrite);
            ent.TransformBy(EM);
            if (msg1.Contains(ent.Layer))
                ids.Add(id);
    var db = doc.Database;
    ObjectId MsId = SymbolUtilityServices.GetBlockModelSpaceId(db);
    sourceDb.WblockCloneObjects(ids, MsId, mapping, DuplicateRecordCloning.Ignore, false);
Here’s my attempt using python script in Dynamo…
import sys
import fnmatch
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
# axtra for ReadDwgFile
from System.IO import FileShare
bn = IN[1] #example: "TAN"
LF = IN[2] #exxample: "ZONE*H*"
# missing ... user select nested enttity for the transform matrix
editor = adoc.Editor
xrefGraph = adoc.Database.GetHostDwgXrefGraph(True)
xrefNode = xrefGraph.GetXrefNode(bn)
xrpath = ""
with OpenCloseTransaction() as tr:
    xrbr = tr.GetObject(xrefNode.BlockTableRecordId, OpenMode.ForRead)
    xrpath = xrbr.GetXrefDatabase(False).Filename
ids = ObjectIdCollection()
with Database(False, True) as db:
    db.ReadDwgFile(xrpath, FileShare.ReadWrite, False, "")
    xrMsId = SymbolUtilityServices.GetBlockModelSpaceId(db);
        xrMS = tr.GetObject(xrMsId, OpenMode.ForWrite)
        for id in xrMS:
            try:
                ent = tr.GetObject(id, OpenMode.ForWrite)
                if fnmatch.fnmatch(ent.Layer,LF):
                    # ent.TransformBy(EM);
                    ids.Add(id)
            except:
                continue
        #mapping = IdMapping()
        #MsId = SymbolUtilityServices.GetBlockModelSpaceId(adoc.Database)
        #db.WblockCloneObjects(ids, MsId, mapping, DuplicateRecordCloning.Ignore, False)
        #with adoc.LockDocument():
        #    with adoc.Database as docdb:
        #        with docdb.TransactionManager.StartTransaction() as t:
        #            mapping = IdMapping()
        #            MsId = SymbolUtilityServices.GetBlockModelSpaceId(docdb)
        #            ms = t.GetObject(MsId,OpenMode.ForWrite)
        #            db.WblockCloneObjects(ids, MsId, mapping, DuplicateRecordCloning.Ignore, False)
        #            t.Commit()
OUT = ids
These lines result in Lock Violation error …
And these lines result in error … was not open for write …
                    t.Commit()
? I have something the wrong way around ?
Here are a few pointers to help clean up your code and get it working
With AutoCAD all actions on the document should be inside a transaction with a locked document
Following lines are outside the transaction
xrpath = ""
You also use the with OpenCloseTransaction() as tr: I have not used this class as typically a transaction is called on a particular database object. If you make any changes to the database a tr.Commit() should be called
In python the with statement is used to encapsulate code for cleaner execution as it automatically tries to clean up memory at completion. Nesting here is important. This line ids = ObjectIdCollection() brings the nesting back to the left and effectively closes the prior with statement so your transaction is now closed
Next you are trying to “side load” the xref database for Tan and transform all objects on layer(s) that match ZONE*H*. Note minor typo with a semi-colon at end of line 49
The python library fnmatch is for Unix filename matching and although it does work you could use string methods if ent.Layer.startswith("ZONE") and "H" in ent.Layer: or a regular expression if re.fullmatch("^ZONE.*H.*$", ent.Layer):
You will have to save the side loaded xref database for the changes to be permanent
I would look at Kean’s C# code for clues how to do this here → Modifying the contents of an AutoCAD xref using .NET
Silly Me!!! It’s working now! … very first sentence … With AutoCAD all actions on the document should be inside a transaction with a locked document … that solved it …
Thank You!!!
