Read linked revit model in Dynamo
I have linked a Structural model in Architectural model. Now, I want to place plaster on the beams, columns of the linked model. The default dynamo nodes don’t read any column or beam existing within the revit file. Is there any custom package that can be used for this purpose?
When dealing with link files i now use Bimorph nodes to get the link file(s) and the link elements
@salmanjavaid2000 ,
these packages are realy strong
Thanks. it worked :slight_smile:
Also, any clue on how to join the model elements with linked elements. I have tried this script, but results in nothing.
You can’t join element in a link file and an element in the parent file
Oh welll.
Thanks for help though.
You can use a node like elements from cataegory on document from nodes of Geniusloci for example
