Get and set From room parameter for doors
Hi all. Im trying to get and set the from room parameter in doors. Only thing is I am not sure if I can use the get parameter with this one. I tried it in dynamo. Ended up being zero
There is a node in clockwork package that can get a doors rooms. You cannot set the rooms as it is made by revit automatically.
I dont want to set the rooms. I want to get the doors associated with the specific room and filter the list to only include the 95 BO. I have half it it solved, thanks
I just need to filter the doors to the 95 bo and its not working
Try family type name instead of string from object
I think it’s useful if you show the outputs from your nodes…
My suspision is that you have a long list of family types as strings, and you have ‘contains’ for 3 values.
I think you’ll need to use cross lacing on your ‘contains’ to run your list of types against each value… Then you’ll use a ‘list contains’ ‘true’ to get any family which had a true against it… you might need a list transpose, I’m not sure…
Apologies I don’t have time to build it myself right now.
Hope that helps,
Mark
What am I doing wrong?. I used this method before and its not working
some odd reason you need to flatten the list from the output
