Hi @leonard.moelders ,
I want to use the same code with CPyton3 but i get a warning that the object has no attribute Close.
Do you have an idea how to solve it?
Hi @Mohamad_Kayali ,
here a solution
import sys
import System
from System.Runtime.InteropServices import Marshal
clr.AddReference('Microsoft.Office.Interop.Excel, Version=11.0.0.0, Culture=neutral, PublicKeyToken=71e9bce111e9429c')
from Microsoft.Office.Interop import Excel
def excel_close():
xlApp = Excel.Application(Marshal.GetActiveObject("Excel.Application"))
allWorkbooks = Excel.Workbooks(xlApp.get_Workbooks())
lst_WkbsName = [Excel.Workbook(x).get_Name() for x in allWorkbooks]
for wb in allWorkbooks:
wb = Excel.Workbook(wb)
wb.Close()
xlApp.Quit()
excel_close()
Please note that this solution Marshal.GetActiveObject() will not work with Revit 2025+ (.Net Core)
Alternative solutions:
- use a python module as comtypes.
- Kill Excel Process
- build or use a C# library
- use Marshal.BindToMoniker (if you know the Excel path)
I’m getting another warning ( Workbook has no attribute get_Name)
With which version of Revit ? 2025 ?
try to comment or remove this line
2023, it worked after commenting the lined you have mentioned. Thank you ![]()
