Hi All,
Quick question. How do I open a particular Excel file using python? Don’t want to write or read the info, just open the file?
Thanks in advance!
Hi All,
Thanks in advance!
Hi @PauLtus, I’d like to use it first, to know how can I call excel files from python and also because it is a part of a larger python code.
The example you mentioned it is what I want but using only python. Is it possible?
Thanks in advance!
Thanks @PauLtus
It’s possible! If you want to background-open the Excel file for editing (as part of your Python script) you can double-click on Konrad’s Write Excel node in the Bumblebee package to read through the process.
I have no idea about your level of experience - it’s not for beginners. Also, check out the Microsoft Office Interop library for Excel. If this process doesn’t make sense to you, I would just suggest using Dynamo.
Thanks @oliver.green. I managed to do this (the path to the excel file was stored in my project information):
clr.AddReference('RevitAPI')
clr.AddReferenceByName('Microsoft.Office.Interop.Excel, Version=11.0.0.0, Culture=neutral, PublicKeyToken=71e9bce111e9429c' )
from Microsoft.Office.Interop import Excel
from System.Runtime.InteropServices import Marshal
ruta = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_ProjectInformation).ToElements()[0].LookupParameter('RUTA PLANILLA MUROS').AsString()
#abrir el libro de excel y extrae las columans relevantes
ex = Excel.ApplicationClass()
ex.Visible = True
workbook = ex.Workbooks.Open(ruta)
OUT = 'Listo!'
Cheers!
Hi, I am trying to use your code but I have an error >>
File “”, line 16, in
AttributeError: ‘NoneType’ object has no attribute ‘AsString’
and there is no option to add the file path to make sure that file will be updated?
What are you trying to do? Do you use same code? Can you share your code?
He has that parameter in project. Do you have the same?
I try to update file excel when I edit it without loading it again… in a traditional way when I use read excel file and make file from the path it’s working but when I make edit on excel file there is no change in dynamo until reload it again
door pts.xlsx (9.2 KB) test 2.dyn (4.1 KB)
You don’t need Python for that. If you use File Path > File From Path> Data.ImportExcel combination and make a change in excel and then save it in Automatic mode in Dynamo, it will be updated automatically.
thanks deniz ^^
