I would like to perform soil volume calculations in the following manner.
- Edit Subassembly values
- Corridor shape is changed in response to 1.
- Corridor Surface is created to match the Corridor created in 2.
- Calculate soil volume using Corridor Surface in 3.
However, I am now stuck at 3. I have been able to work up to 2 with the attached Dynamo, but have not been able to create a Corridor Surface that matches the Corridor I created.
How can I create a Corridor Surface?
Thank you in advance.
Subassembly_Parameter1.dyn (46.3 KB)
コリドーedit.dwg (1.9 MB)
