Is there a way to expand a bounding box really quick?
I feel like this is the only obvious way, but to me it feels clunky.
And even after this:
FYI I need to check for clashes and I wanted to manually check off a list of elements. Since it’s 22 objects its better to not overthink it. I am purely curious if there is a good way to just expand a bounding box
Since bounding boxes are typically axis aligned cubes, this is my first reaction:
(Edit: Yes, there are non-axis aligned bounding boxes now, but in Revit they are still axis aligned, so that does not feel relevant here.)
This is what I was looking for indeed. Didn’t think of the word: Scale
and with an non xy aligned one mabe
Home.dyn (12.0 KB)
Thanks to @c.poupin for that tip
Careful with scale.
- Dimensions are relative - a cuboid of 10x1x1 scaled by a factor of 10 will be 100x10x10. This likely means you’re using the relative size of the cuboid to get an equal offset if you go that root.
- Origin point will likely need to be something other than the internal origin (what the method @john_pierson shows would use) - if the 10x1x1 cuboid had it’s centroid at 5,5,5 after scaling by 10 it’d be at 50,50,50.
Instead I recommend either going with a vector method if you’re in the Revit API, or Solid.ThinShell if you’re utilizing the Dynamo Geometry method. For clash detection with a tolerance my personal preference would be something like:
- Get the solids from the object via Element.Solids
- Enlarge each solid by Solid.ThinShell and then union all of the enlarged solids and the original solids into two solids (one for tolerance and one for physical intersection)
- Get the bounding box of the thin shell (axis aligned or not - I can’t recall if the conversion from non-orthgonal bounding box to a Revint internal one utilizes the transform property so best to test this)
- Use the bounding box as a quick filter on the complete element set.
- Use the thin shell solid as the tolerance filter applied atop the bounding box filtered element set.
- Use the original solid as the physical clash filter applied atop the bounding box filtered element set.
- Report the findings.
Incase it helps, here’s the “thin shell to expand the cuboid by a distance” graph:
Like I said I’m not looking to overcomplicate things. I noticed that the boundingbox → section box made the view supercropped around the object. If I did it manually by clicking the element and making a section box (with the shortcut bx) I noticed the section box started much larger.
I used a percentage as reference. The bigger the object, the more space around it we need for context anyway
I get you - just wanted to assure that you weren’t caught off guard by the scaling woes - I’ve previously seen simple projects go sideways by not accounting for that complexity early on.
a solution that uses the Revit API Outline object (which has a Scale method) and the BoundingBox.ByMinimumVolume() method.
# Import RevitAPI
clr.AddReference("RevitAPI")
def set_SectionBox(view3d, ds_bbx):
global fscale
# convert bbx
tf_view = view3d.CropBox.Transform
cs = ds_bbx.ContextCoordinateSystem
tf = Transform.Identity
tf.BasisX = cs.XAxis.ToXyz()
tf.BasisY = cs.YAxis.ToXyz()
tf.BasisZ = XYZ.BasisZ #coord_system.ZAxis.ToXyz()
tf.Origin = cs.Origin.ToXyz()
ptmax_before_cs = ds_bbx.MaxPoint.Transform(cs.Inverse())
ptmin_before_cs = ds_bbx.MinPoint.Transform(cs.Inverse())
# use outline for scale
outline = Outline(ptmin_before_cs.ToXyz(), ptmax_before_cs.ToXyz())
outline.Scale(fscale)
newbox = BoundingBoxXYZ()
newbox.Max = outline.MaximumPoint
newbox.Min = outline.MinimumPoint
newbox.Transform = tf
view3d.SetSectionBox(newbox)
views = UnwrapElement(IN[0])
ds_bboxes = IN[1]
fscale = IN[2]
if isinstance(IN[0], list):
if isinstance(IN[1], list):
OUT = [set_SectionBox(x, y) for x, y in zip(views, ds_bboxes)]
OUT = [set_SectionBox(x, ds_bboxes) for x in views]
OUT = set_SectionBox(views, ds_bboxes[0])
OUT = set_SectionBox(views, ds_bboxes)
OUT = views
For sure, this is the same logic that I believe the old Coins Auto-Section Box plugin used too.
