I want to shorten the start point of my curve by a certain distance. I was trying to use Curve.ExtendStart with a negative value but it does not accept that even though the input type is double. Is there any such node available which could do this? Essentially what I want is just a reverse of this node.
I was trying to find some direct node to Shorten it but I couldn’t find any (apart from one node in Dynamo Rebar, but that shortens it from both ends which I don’t want)
The curve I want to use is a simple straight line. So any other method to do this is also appreciated.
