Hi.
Yes, object binding needs a special chapter all by it self. @mzjensen explains it pretty good in this post.
In Civil 3D 2023 you can remove the binding under ”Dynamo” menu or select how binding should be stored.
The dark side is that this setting is not tied to the graph, it will be tied to Dynamo and needs to be changed if you want to run another graph with another setting
I actually set it to not keep binding but it might be incorrect in your situation
