Question about if statement import from Excel
This is my first post and i’m new in Dynamo.
I have a question about the math. formula. In excel i have a long formula which contains ifs and “and”. i put directly the excel formula to dynamo, if statements working but one “and” statement is not working.
how can i use “and” in dynamo;
i tried simple part of the code but it is also not working.
IF(&&(500<=height, height<=1000),1,0))
full code;
if(Height<500,(2/1000*(Width+Height))((903.14*((150+Height)/1000))/180)+((Width+Height)2/10000.01),IF(&&(500<=Height,Height<=1000),((2/1000*(Width+Height))((903.14*((150+Height)/1000))/180)+((Width+Height)2/10000.01))+(((((Height/2)+150)/1000)23.14*(90/360))Width/1000),IF(Height>1000,((2/1000(Width+Height))((903.14*((150+Height)/1000))/180)+((Width+Height)2/10000.01))+(((Height+(2150))/1000)23.14(90/360))*Width/1000)))
Thanks,
Burak.
the formula using CodeBlock like this
if
Thank you but, i used formula option. Is there any way to do like this?
This will make thing easier for you.
there is no need to use “IF” in your statement, in your case like this
height>=500&&height<=1000?1:1;
Thank you very much, i solved the problem with separating the if statements instead of “nested if”.
