I have two changeable input values and one output value in my family and i want to do that. For example, if my “a” value is 1 and “b” value is 2, output “c” value must be 10.
İn revit i can do that in this way, if(a=1,b=2),10,0) but i didn’t do that with dynamo codes ? Could you help me ?
In a code block try this:
Input =="a"?
1:
Input == "b"?
2:
Input == "c"
10:
"Unexpected value! Check your dataset!"
That’s from memory on my phone so it may be off. Cpu is locked up doing some heavy lifting at the moment so I can’t confirm.
General idea is:
Test ?
IfTrue :
IfFalse;
The ? marks the end of the test and initialized the function so don’t forget it.
The : divides the true from false so don’t forget it either.
The ; marks the end of the line of code, so… well you get the idea.
Nesting can go pretty deep. I haven’t found a limit yet anyway. Nesting is also possible on either the true statement or the false statement:
Test ?
IfTrueTest?
IfTrueTestTrue:
IfTrueTestFalse:
IfFalseTest?
IfFalseTestTrue:
IfFalseTestFalse;
Helps to use offset tabs (though the forum doesn’t like typing them on a phone) for various levels of nesting so you know where you are in a given statement.
