How to Get Location Line of Arc Wall in PythonScript?
Hi All,
There is a node “Element.GetLocation” can help to get the Arc Wall Curve.
I am now trying to use python script to get the curve, because I need the arc center point for some calculation.
But I can’t, the Error is:
My Script:
clr.AddReference(‘RevitAPI’)
clr.AddReference(‘RevitNodes’)
from Revit.Elements import *
ele = IN[0]
cp = UnwrapElement(ele[0]).Location.Curve.CenterPoint
OUT = cp
It is quiet weird that Arc has no attribute “CenterPoint” (but I can find it from RevitAPI document).
Anyone know why?
Thank you.
Oh, I found the reason :sweat_smile:
There is no CenterPoint on Revit 2017 Arc Attribute… it should be Center…:sweat_smile:
Revit API always makes me confuse, why does autodesk change API name in each revit version…
