Hi all,
I need to get the element’s IDs from the list using python.
What I am doing is not working. Any help?
import sys
import System
from System import Int16, Int32, Int64, String
clr.AddReference('RevitAPI')
def getElementByValue(v):
# if value is ElementId or Reference object
if isinstance(v, (ElementId, Reference)):
return doc.GetElement(v)
# if value is a integer
elif isinstance(v, (int, Int16, Int32, Int64)):
return doc.GetElement(ElementId(v))
# if value is a String 'integer'
elif isinstance(v, (str, String)) and str(v).isdigit():
return doc.GetElement(ElementId(int(v)))
# if value is a String Unique Id
elif isinstance(v, (str, String)) and '-' in str(v):
ids = IN[0]
out = []
for id in ids:
out.append(getElementByValue(id))
OUT = out
@aafonsoBYKA8 ,
You just get Ids from the element not from the name…
(here is your code pasted)
import sys
clr.AddReference('System')
# if value is a String ‘integer’
elif isinstance(v, (str, String)) and ‘-’ in str(v):
ids = IN[0]
out = []
for id in ids:
OUT = out
an example using FilteredElementCollector with filter
import System
def get_ElementIds_from_name(name):
rule = ParameterFilterRuleFactory.CreateEqualsRule(ElementId(BuiltInParameter.ELEM_TYPE_PARAM), name, True)
filt = ElementParameterFilter(rule)
return FilteredElementCollector(doc).WherePasses(filt).WhereElementIsNotElementType().ToElementIds()
OUT = [get_ElementIds_from_name(name) for name in IN[0]]
I have several walls, with diferent types. I need to get the IDs of all walls with the prefix “NLA_42”.
Can you show me the python script for Get ID by name?
import System
it is the same from @c.poupin
