0 list is an Autodesk.Revit.DB.ElementId
1 list is a number
How do I get 1 to output the Autodesk.Revit.DB.ElementId?
@Alien ,
did you load libraries also ?
clr.AddReference('RevitAPI')
clr.AddReference('System')
views = UnwrapElement(IN[0])
ids = []
for i in views:
ids.Add(i.Id)
OUT = ids
KR
Andreas
Hello, I don’t know if this is what you are looking for
clr.AddReference("RevitAPI")
app = uiapp.Application
views=UnwrapElement(IN[0])
v_Id=[int(v.Id.ToString()) for v in views]
v_Id_revit=[v.Id for v in views]
OUT = v_Id,v_Id_revit
cordially
christian.stan
It was because I didn’t unwrap!! Doh!
Thank you ![]()
@Alien ,
the small things ![]()
