Not sure why split does not work. I select text nodes
[0] 00.15
[1] 01.152
and should replace 1st one with None
ControlTextNode_V12.dyn (4.0 KB)
[0] 00.15
[1] 01.152
Typically that warning is given when you have mixed tabs and spaces. It is very important to use only tabs. The indentation might look correct, but if they are not identical python is not happy.
Dear Michal,
It should work now
@Alberto_Tono thanks for help. I run your script and unfortunately got this warning.
Warning: IronPythonEvaluator.EvaluateIronPythonScript operation failed. _
_ File “”, line 42, in
AttributeError: ‘TextNote’ object has no attribute ‘split’
so this is issue line:
if len(i.split('.')) > 0:
from my code:
from re import search
atext3 = []
atext4 = []
#unwrap all elements to use with API
elements = []
for i in IN[0]:
elements.append(UnwrapElement(i))
for i in elements:
id = i.Id
k = str(i.Text)
atext3.append(k)
if not len(list(i.Text)) > 5:
if i.split('.')[0:2].isdigit():
if i.split('.')[3:].isdigit():
i.Text = ''
atext4.append(i.Text)
#Assign your output to the OUT variable
OUT = atext3, atext4
could you share the .rvt file also please
what revit and dynamo are you using also?!
I am using now 16.0.1161.0 20160720_0715(x64) Update6 for R2 and Dynamo 1.2.0.2960. Revit - this is simple just go to Drafting view and create few text notes then Select Elements in Dynamo.
I think issue is when I try to get text from element and then perform .split on that… I tested to assing string to k before perform this function.
I have the same issue with 2016 I think it is about the attribute “split” isn’t implemented in Revit 2016.
But I am not so sure about that. I apologize I am not able to help you.
The Image is about Revit 2017. There it works.
Can you tell us input and desired output? Tried to understand code, but failed
@Tomasz_Puchala
I am trying to find way to filter text and got 4 methods but can not get it to work right now.
So I want to find text that follow my logic…in this example “DigitDigit.DigitDigit” this text will be replaced with “” Nothing . (i.Text = '') Anyway this search could be any complex logic. In python those works but in Dynamo not really.
ps, No idea why conde is not recognized
if not len(list(i.Text)) > 5: if len(i.split('.')) > 0: if i.split('.')[0:2].isdigit(): if i.split('.')[3:].isdigit(): i.Text = ''
for i in elements: match = search('\d{2}\.\d{2}$',i.strip()) if match: atext1.append(match.string) i.Text= ''
from re import search for i in elements: k = i.Text match=search('\d{2}\.\d{2}$',k.strip()) if match: atext1.append(match.string) i.Text= ''
for i in elements: id = i.Id k = i.Text if k.split('.')[0:2].isdigit(): i.Text= ''
sth like this?
clr.AddReference("RevitAPI")
app = uiapp.Application
#The inputs to this node will be stored as a list in the IN variable.
#from re import search
atext3 = []
atext4 = []
elements = []
for i in IN[0]:
b=[]
for i in elements:
k = str(i.Text)
atext3.append(k)
for j in atext3:
if len(j) >= 5 and j[2] == '.':
if j[0:2].isdigit() and j[3:].isdigit():
atext4.append('')
atext4.append(j)
atext4.append(j)
OUT = atext3,atext4
@Tomasz_Puchala
Hi Tomasz I think I got it. Had to do some modification but here is final product.
atext3 = []
atextTrue = []
atextFalse = []
atextAll = []
elements = []
for i in IN[0]:
for i in elements:
atext3 = i.Text
if len(atext3) == 5 and atext3[2] == '.':
if atext3[0:2].isdigit() and atext3[3:5].isdigit():
i.Text = 'deletedTEXT'
atextTrue.append(i.Text)
atextFalse.append(i.Text)
atextAll.append(i)
OUT = atextTrue, atextFalse, atextAll
