Python Scrips Newbie - "expected an indented block"
I’m trying to create new materials with Python script. I have used @Scott_Crichton script from this topic but Im getting an error “expected an indented block”. I know that @mimp had the same problem, but this has not been resolved.
Have you any ideas what might be wrong with that script?
I’m just a total beginner :confused:
clr.AddReference("RevitAPI")
def ToRevitColor(dynamoColor):
return Color(dynamoColor.Red, dynamoColor.Green, dynamoColor.Blue)
def ToDynamoObject(revitObject, isRevitOwned=False): # isRevitOwned should be False if Dynamo script created the object.
return revitObject.ToDSType(isRevitOwned)
names = IN[0]
transparencies = IN[1]
colors = IN[2]
newMaterials = []
for mat_name, transparency, color in zip(names, transparencies, colors):
new_mat_id = Material.Create(doc, mat_name)
new_mat = doc.GetElement(new_mat_id)
new_mat.Color = ToRevitColor(color)
new_mat.Transparency = transparency
newMaterials.append(ToDynamoObject(new_mat))
OUT = newMaterials
Thanks in advance
Jack
Here is attached my .dyn file
New_Materials_Script.dyn (39.5 KB)
As a start, for this section:
OUT = newMaterials
Indent all lines with one Tab spacing, as this lets the for function know what it is trying to apply.
So the script has to look like this?
names = IN[0]
colors = IN[2]
newMaterials = []
	OUT = newMaterials
If so, then it is still not working. And error is same.
Not at the PC right now, so can’t plug the code into Dynamo.
Take the indent off the OUT line and see if that helps.
You need to indent the definitions too. Add a tab before “return” for both definitions.
Also, remove indent on OUT. It should sit out of the for loop.
Also also, transaction should really sit out of the loop too, but it will still work as is
Ok, so now it shows me another error.
File “”, line 29, in
Exception: The given value for name is already in use as a material element name.
Parameter name: name
At this moment my script looks like this:
names = IN[0]
colors = IN[2]
newMaterials = []
OUT = newMaterials
try this…
names = IN[0]
colors = IN[2]
newMaterials = []
    try:
    except:
        newMaterials.append(None)
OUT = newMaterials
I have added Try/Except. It should pass now, but it will return a null if there was an error (for instance if you have a material with that name already in the project).
Hang on, I edited this in the forum and Python gets a little funny with mixed tabs and spaces and failed when i ran it. I have also pulled the transaction out of the loop…
names = IN[0]
colors = IN[2]
newMaterials = []
	try:
	except:
OUT = newMaterials
Wow! It’s working! Thank you.
Pitty that it is not overriding materials :frowning:
Nah, this creates new materials, i can do a condition to check first if material exists and use that instead of creating a new one.
I will sort in the morning as it’s late where i am.
Hi @Jacko
This should now override any materials with the same name.
I have also added an option to disable whether the Material is Owned by Dynamo (this feature can be annoying sometimes as Dynamo keeps track of which Elements it made and always remembers these for modification, now you have a choice of whether you want to do this. I prefer to disable this personally, particularly on a generic script that I will use many times in different situations on the same document).
I have also made sure that even if you are passing in one one item (not in a list), that this will still work and I have added a new OUT variable for errors that will give you a description of the error it encountered.
Additionally, I have commented on what’s going on to make it forum friendly so people new to python can understand step by step.
################ Definitions ################
# Convert DSCore Colour to Revit Colour...
# Add Dynamo Ownership to Element...
# Gets the Material Id by name from a list of Materials ...
def GetMaterialIdByName(mat_Name, mats):
	return next((m.Id for m in mats if m.Name == mat_Name), None)
# Used to Ensure that object is in a list...
def tolist(obj1):
	if hasattr(obj1,"__iter__"): return obj1
	else: return [obj1]
################ IN Variables ################
names = tolist(IN[0])
transparencies = tolist(IN[1])
colors = tolist(IN[2])
toDynObj = tolist(IN[3])[0]
################ OUT Variables ################
newMaterials = []
err = []
################ Main Body ################
# Get all the Materials that are currently created in the Revit doc...
mats = FilteredElementCollector(doc).OfClass(Material).ToElements()
	try:
		# Check if material exists already...
		new_mat_id = GetMaterialIdByName(mat_name, mats)
		# Create one if it doesn't...
		if not new_mat_id:
		# Get Material from Revit doc...
		# Set Material colour...
		# Set Material Transparency...
		# If toDynObj is true, Dynamo will own the Elements it creates and overwrite those...
		if toDynObj:
		# if toDynObj is false, Dynamo will not own this Element...
			newMaterials.append(new_mat)
		err.append(None)
	except Exception, ex:
		err.append(ex.message)
################ OUT ################
OUT = newMaterials, err
Cheers,
Dan
Hi jacek -
Try this code if you can make any sense of it
@Daniel_Woodcock1 Sir, you are great!
Well it is a real black magic for me :smiley:
I see I have a lot to learn.
You’re welcome @Jacko! Glad this is now working for you!
Ah, it might seem like black magic now, but I’m sure soon enough, you’ll be up and running with python and this will look simple! It’s scarier than it looks! :grin:
Indentation means the space from margin to the begin of characters in a line. Python language is a very sensitive language for indentation, it has caused confusion for many beginners. Putting in an extra space or leaving one out where it is needed will surely generate an error message . Some common causes of this error include:
  • Forgetting to indent the statements within a compound statement.
  • Forgetting to indent the statements of a user-defined function.
The error message IndentationError: expected an indented block would seem to indicate that you have an indentation error. It is probably caused by a mix of tabs and spaces .
