Hello
On the code below I keep getting the error message “Expected An Indented Block”. The code is supposed to create a list of new Filter Rules (I can’t get the OOTB node to create a list of Rules, only a Single Rule).
clr.AddReference("RevitAPI")
import System
dataEnteringNode = IN
parameter = IN[0]
ruleValues = IN[1]
#TransactionManager.Instance.EnsureInTransaction(doc)
rulesList = []
#If the rule exists then hopefully the Try statement will hop over it...
try:
for value in ruleValues:
#requires parameter Id, string for filter name and boolean for if Case Sensitive or not
newRule = ParameterFilterRuleFactory.CreateEqualsRule(parameter.Id, value, false)
rulesList.append(newRule)
#rulesList.append(ParameterFilterRuleFactory.CreateEqualsRule(parameter.Id, value, false))
except:
pass
#TransactionManager.Instance.TransactionTaskDone()
OUT = rulesList<a class="attachment" href="//cdck-file-uploads-us1.s3.dualstack.us-west-2.amazonaws.com/flex022/uploads/dynamobim/original/3X/5/3/538f5e14df3f6a4f6bc5546c7cf2951db1fea042.dyn">WIP View Filters Create From Filled Regions.dyn</a> (21.7 KB)<a class="attachment" href="//cdck-file-uploads-us1.s3.dualstack.us-west-2.amazonaws.com/flex022/uploads/dynamobim/original/3X/5/3/538f5e14df3f6a4f6bc5546c7cf2951db1fea042.dyn">WIP View Filters Create From Filled Regions.dyn</a> (21.7 KB)
