Expected an indented block erro
I’d be appreciated if anyone could help/advise on why am I getting the “expected an indented block” error. Code below.
Thanks in advance.
Import clr
Import DocumentManager and TransactionManager
app = uiapp.Application
Import RevitAPI
clr.AddReference("RevitAPI")
FilesToIssue = IN[0]
if not isinstance(FilesToIssue,list):
	FilesToIssue = [FilesToIssue]
DestinationFolder = IN[1]
options = OpenOptions()
options.DetachFromCentralOption = DetachFromCentralOption.DetachAndPreserveWorksets
worksharingOptions = WorksharingSaveAsOptions()
worksharingOptions.SaveAsCentral = True
SaveOptions = SaveAsOptions()
SaveOptions.SetWorksharingOptions(worksharingOptions)
tOptions = TransactWithCentralOptions()
rOptions = RelinquishOptions(False)
rOptions.StandardWorksets = True
rOptions.ViewWorksets = True
rOptions.FamilyWorksets = True
rOptions.UserWorksets = True
rOptions.CheckedOutElements = True
sOptions = SynchronizeWithCentralOptions()
sOptions.SetRelinquishOptions(rOptions)
sOptions.Compact = True
sOptions.SaveLocalBefore = True
sOptions.SaveLocalAfter = True
RestOfSheets = []
splashscreen = []
for file in FilesToIssue:
	modelpath = FilePath(file)
	FileName = file.split("\\")[-1]
	newdoc = app.OpenDocumentFile(FilePath(file),options)
	newdoc.SaveAs(DestinationFolder+"\\"+FileName,SaveOptions)
	viewscollector = FilteredElementCollector(newdoc)
	views = viewscollector.OfCategory(BuiltInCategory.OST_Views).ToElementIds()
	sheetscollector = FilteredElementCollector(newdoc)
	sheets = sheetscollector.OfCategory(BuiltInCategory.OST_Sheets).ToElementIds()
	for sheet in sheets:
    	if sheet.Name =! "Splash Screen":
    		RestOfSheets.append(sheet)
	TransactionManager.Instance.EnsureInTransaction(newdoc)
	newdoc.Delete(views)
	newdoc.Delete(RestOfSheets)
	TransactionManager.Instance.ForceCloseTransaction()
	newdoc.SynchronizeWithCentral(tOptions,sOptions)
	newdoc.Close(False)
OUT = views, sheets, list
You’re mixing tabs with spaces so the interpreter doesn’t like it. Its a bit of a nuisance to track down since you can’t see any difference but the best thing to do is paste your code into a text editor and search for a 3x or 4x space then replace it with a tab then paste the code back in and it will work.
Nice one Thomas, thanks for the prompt reply. I’ve moved it to Word and indeed there’s a bit of a mix of spaces and tabs. I’m using Notepad++ for coding, would you recommend any other better?
Yeah, use Visual Studio Code, create dedicate projects (external py files) for each of your Dynamo graphs and use the Python from string node to run your py files in Dynamo instead. One of the other benefits (aside from being in a decent IDE) is you can re-use your python code in other Dynamo graphs and avoid duplication so your code is easier to maintain.
Thanks for that Thomas, much appreciated :+1:. I do use Visual Studio when messing with the Revit API and addins creation however not using Python for that one. I’ll start doing so…
