I use python script to select elements from linked model visible in section, but on some sections there is error like this:
Don’t have any idea what it means and there is no location E:\Ship24.2.1 on my computer. Could you help please?
Going to be impossible to help you without seeing the code within your Python script.
Can you please add it to your post between two lines of ``` for formatting?
It looks to be an error with the document being used in line 76 though.
Here is the code:
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
def gen_PairPts(*args):
"""generator for point pair loop
for idx, pt in enumerate(args):
try: yield pt, args[idx + 1]
except : yield pt, args[0]
def solid_fromBBX(bbox):
pt0 = XYZ( bbox.Min.X, bbox.Min.Y, bbox.Min.Z )
pt1 = XYZ( bbox.Max.X, bbox.Min.Y, bbox.Min.Z )
pt2 = XYZ( bbox.Max.X, bbox.Max.Y, bbox.Min.Z )
pt3 = XYZ( bbox.Min.X, bbox.Max.Y, bbox.Min.Z )
#create generator
pairPts = gen_PairPts(pt0, pt1, pt2, pt3)
#Create loop, still in BBox coords
edges = List[Curve]()
for pt1, pt2 in pairPts:
edges.Add(Line.CreateBound( pt1, pt2 ))
height = bbox.Max.Z - bbox.Min.Z
baseLoop = CurveLoop.Create( edges )
loopList = List[CurveLoop]()
loopList.Add( baseLoop )
preTransformBox = GeometryCreationUtilities.CreateExtrusionGeometry( loopList, XYZ.BasisZ, height )
transformBox = SolidUtils.CreateTransformed( preTransformBox, bbox.Transform )
return transformBox
def toList(x):
if isinstance(x, (list, dict)) or \
(hasattr(x, "GetType") and x.GetType().GetInterface("ICollection") is not None):
return x
else : return [x]
lst_View = toList(UnwrapElement(IN[0]))
catList = toList(UnwrapElement(IN[1]))
catBiplst = [ System.Enum.ToObject(BuiltInCategory, int(x.Id.ToString()) ) for x in catList]
linkInstances = FilteredElementCollector(doc).OfClass(DB.RevitLinkInstance)
out = []
for view_ in lst_View:
temp = []
if view_.ViewType == ViewType.Section:
for lnkInstance in linkInstances:
lnk_doc = lnkInstance.GetLinkDocument()
transf = lnkInstance.GetTotalTransform()
bbxView = view_.CropBox
solidbbx = solid_fromBBX(bbxView)
# apply link instance transform and create Filters (Solid + Categories)
solidbbx = DB.SolidUtils.CreateTransformed(solidbbx, transf.Inverse)
filterSolid = ElementIntersectsSolidFilter(solidbbx)
cats = List[BuiltInCategory](catBiplst)
filtercat = ElementMulticategoryFilter(cats)
elemIntersect = FilteredElementCollector(lnk_doc).WherePasses(filterSolid).WherePasses(filtercat).WhereElementIsNotElementType().ToElements()
# FOR DEBUG
#out.append([lnkInstance.Name, elemIntersect, solidbbx.ToProtoType()])
temp.append([lnkInstance.Name, elemIntersect])
elif view_.ViewType in [ViewType.CeilingPlan, ViewType.FloorPlan]:
#get bootom and top Elevation of active viewrange
viewRange = view_.GetViewRange()
topClipPlaneId = viewRange.GetLevelId(PlanViewPlane.TopClipPlane)
topClipPlane = doc.GetElement(topClipPlaneId)
topOffset = viewRange.GetOffset(PlanViewPlane.TopClipPlane)
bttmClipPlaneId = viewRange.GetLevelId(PlanViewPlane.BottomClipPlane)
bttmClipPlane = doc.GetElement(bttmClipPlaneId)
bttmOffset = viewRange.GetOffset(PlanViewPlane.BottomClipPlane)
# get min and max from active ViewRange
bbxActView = view_.CropBox
bbxActView.Min = XYZ(bbxActView.Min.X, bbxActView.Min.Y, bttmClipPlane.ProjectElevation + bttmOffset)
bbxActView.Max = XYZ(bbxActView.Max.X, bbxActView.Max.Y, topClipPlane.ProjectElevation + topOffset)
bbxActView.Transform = transf.Inverse
# create Solid Filter
solidbbx = solid_fromBBX(bbxActView)
# create categories filter
# FOR DEBUG
#out.append([lnkInstance.Name, elemIntersect, solidbbx.ToProtoType(), bbxActView.Min.ToPoint(), bbxActView.Max.ToPoint()])
out.append([view_, temp])
OUT = out
