I have an error with the script page 176 of the book, in the filters by boolean operation. In the note it is specified that you must modify the subroutine (def) “solidoCampVisual”
Does anyone have any ideas?
I can pass the codes if I need to.
Daniel OLIVES
Lyon-FRANCE
Contact the author I’d say, or share the error in more detail. Most of us dont have the book, and if an author wants to lock away knowledge in a paid resource it is on them to troubleshoot with its customers imo.
Hi GavinCrump,
Thank’s for your answer.
Here is the code:
import sys
#sys.path.append('C:\Program Files\IronPython 2.7\Lib')
#2022/12
sys.path.append('C:\Program Files\IronPython 3.4\Lib')
import System
from System import Array
import traceback
clr.AddReference('RevitAPI')
clr.AddReference('System')
from System.Collections.Generic import List; BuiltInCategory
# - - - - M.E.P.- - - - - - - - - -
from Autodesk.Revit.DB.Architecture import *
from Autodesk.Revit.DB.Mechanical import *
app = uiapp.Application
# - - - - - - FONCTIONS - - - - - - -
def toList(x):
if isinstance(x, list):
return x
elif hasattr(x, "GetType") and x.GetType().GetInterface("IEnumerable") is not None:
return x
else :
return [x]
def solidVisualField(vue):
crMngr = vue.GetCropRegionShapeManager()
vrange = vue.GetViewRange()
desf = vrange.GetOffset(PlanViewPlane.TopClipPlane) - vrange.GetOffset(PlanViewPlane.ViewDepthPlane)
CropRegion = crMngr.GetCropShape()
lignes = CurveLoop()
[lignes.Append(x) for x in CropRegion[0]]
L = List[CurveLoop]()
L.Add(lignes)
return GeometryCreationUtilities.CreateExtrusionGeometry(L,XYZ(0,0,1),desf)
def RvtGeoADirectShape(solide) :
#Créer un DirectShape à travers un solide, toujours exécuté à l'intérieur d'une opération
listGeo = List[GeometryObject]()
listGeo.Add(solide)
catégorie = ElementId(BuiltInCategory.OST_GenericModel)
ShapeRvt = DirectShape.CreateElement(doc, catégorie)
ShapeRvt.AppendShape(listGeo)
return ShapeRvt
def LnkElemsVisibleInView(link, campoVisual):
"""Le champ visuel est représenté par le solide extrudé qui est créé à partir des lignes de la région de découpe de la vue"""
transf = link.GetTransform()
if not transf.AlmostEqual(Transform.Identity):
campoVisual=SolidUtils.CreateTransformed(campoVisual,transf.Inverse)
filtro = ElementIntersectsSolidFilter(campoVisual)
elems = FilteredElementCollector(link.GetLinkDocument()).WherePasses(filtro).ToElements()
return elems
def solidoHabsLinks(habs):
salida = []
for h in habs:
geo = list(h.ClosedShell)
salida.append(geo[0])
return salida
def LnkhabsEnVista(link, vue):
pièces = FilteredElementCollector(link.GetLinkDocument()).OfCategory(BuiltInCategory.OST_Rooms).ToElements()
areaMin = min([x.Area for x in pièces])
solide = solidVisualField(vue)
campoVisual = solide[0]
desf = solide[1]
habGeo = solidoHabsLinks(pièces)
campoVisual = SolidUtils.CreateTransformed(campoVisual,transf.Inverse)
habEnVista = []
for h,s in zip(pièces, habGeo):
intersc = BooleanOperationsUtils.ExecuteBooleanOperation(campoVisual, s, BooleanOperationsType.Intersect)
area = intersc.Volume / desf
if area >= areaMin:
habEnVista.append(h)
return habEnVista
#Préparation des "entrées" de dynamo pour revit
vue = UnwrapElement(IN[0])
# - - - - - À PARTIR DE MAINTENANT LE CODE - - - - - -
#Faire quelque chose dans la Transaction
links= FilteredElementCollector (doc, vue.Id).OfClass(RevitLinkInstance)
pièces = [LnkhabsEnVista(x, vue) for x in links]
OUT = pièces
And the note added:
Note: The solidVisualField function has been modified by adding as output the prism offset in the index 1, this will allow to calculate the area of the intersection and discard rooms that are partially seen in the view.
Daniel OLIVES
Lyon-FRANCE
Personally the language in the code and the goals of the script aren’t overly clear to me unfortunately. Hopefully the author can assist or someone more familiar with the language or book can help.
Thank’s Gavin, i try to contact Kevin
Daniel
