Using Dynamo 2.0.0 I’m using Ben’s code from this post. This is the image of his code. I keep getting a Warning, operation failed unexpected token “”
Here is a link to an image of my code. I’m new to Python, and spent a hour last night staring at the code looking for typos or incorrect case sensitivity. Thank you, Steve
Thanks, Jonathan, I made the single and double quote changes. It’s still throwing an error. Here is a linkto an image of the updated. And here is a link to the text file of the code.
And I just deleted line 14 and this didn’t correct the error. BTW Can you tell from the code what type of input this code is looking for? I was trying to feed it either an element ID or an element selected.
Please another time post your code using preformatted text (the ‘’</>’’ sign in the editor)
Also you can add pictures to your posts much easier than links to Dropbox
Have a look in line 61, quotation again
Deleting line 14 was not to fix anything, it is simply a redundant line of code
I believe the script require view elements as inputs (not the id’s).
Adding the code below:
# Import RevitAPI
clr.AddReference('RevitAPI')
elementz = UnwrapElement(IN[0])
viewtemplates = list()
views = list()
viewcollector = FilteredElementCollector(doc).OfClass(View)
sheetcollector = FilteredElementCollector(doc).OfClass(ViewSheet)
for view in viewcollector:
if view.IsTemplate == True:
viewtemplates.append(view)
views.append(view)
viewmatches = list()
for elem in elementz:
viewmatchez = list()
viewmatches.append(viewmatchez)
for v in views:
viewelemidz = []
viewelems = list()
viewelems = FilteredElementCollector(doc,v.Id)
for viewelem in viewelems:
viewelemidz.append(viewelem.Id)
for i in range(0,len(elementz)):
elem = elementz[i]
elemid = elem.Id
viewmatchez =viewmatches[i]
if elemid in viewelemidz:
viewmatchez.append(v)
sheetz = list()
for sheet in sheetcollector:
sheetz.append(sheet)
elsheetmatches = list()
elviewmatches = viewmatches[i]
elsheets = list()
for viewmatch in elviewmatches:
sheetnum = viewmatch.get_Parameter(BuiltInParameter.VIEWER_SHEET_NUMBER).AsString()
if sheetnum != '---':
for sheetel in sheetz:
if sheetel.get_Parameter(BuiltInParameter.SHEET_NUMBER).AsString() == sheetnum:
elsheets.append(sheetel)
elsheetmatches.append(elsheets)
OUT = viewmatches, elsheetmatches
Thanks, Jonathan, now I’m getting a new error; Traceback (most recent call); File “”, line 27, in
TypeError: iteration over non-sequence of type Floor. Interestingly I was able to feed it a Select Element and I selected a floor. But for some reason, I couldn’t use the Select Elements Node.
# Import RevitAPI
views = list()
views.append(view)
for v in views:
viewelemidz = []
viewelems = list()
elem = elementz[i]
elemid = elem.Id
sheetz = list()
elsheets = list()
Your scripts only take a input in IN[0] … It’s a good idea to understand what you’re using
The output is defined in your script as viewmatches, elsemarches
The problem that you’re encountering is because your input expects “select Elements”, not “Select Element”
You would have to change the code to take out the looping for multiple selected elements:
I’m not into Dynamo, but here’s what I came up with. also outputs the dwg name in the Dynamo…
clr.AddReference("ProtoGeometry")
# Import RevitAPI
clr.AddReference("RevitAPI")
views = list()
views.append(view)
for v in views:
viewelemidz=[]
viewelems = list()
for i in range(0,1):
elem = elementz
elemid = elem.Id
viewmatchez = viewmatches
sheetz = list()
elsheets = list()
if sheetnum != '-':
