Hi all,
Found the Python-code below in this tread.
It checks a list of viewports, and returns the corresponding minpoint, maxpoint and longitudes.
Only downside is that it returns the output in feet, but i would like mm as output.
Is it possible to add some code to change the output units?
from Autodesk.DesignScript.Geometry import Point as ProtoPoint
# Import geometry conversion extension methods
clr.AddReference('RevitAPI')
doc= DocumentManager.Instance.CurrentDBDocument
dataEnteringNode = IN
maxp = []
minp = []
longitudes = []
longitud = 0
if type(IN[0]) !=list:IN[0] = [IN[0]]
for i in IN[0]:
# doc.Regenerate()
p = UnwrapElement(i).GetBoxOutline()
max = p.MaximumPoint
min = p.MinimumPoint
maxp.append(ProtoPoint.ByCoordinates(max.X,max.Y,0))
minp.append(ProtoPoint.ByCoordinates(min.X,min.Y,0))
longitudes.append(p.GetDiagonalLength())
doc.Regenerate()
OUT = [maxp,minp,longitudes]
