I want to get my offsets in metric system f.e. mm
import System
clr.AddReference('RevitAPI')
clr.AddReference('System')
wall = UnwrapElement(IN[0])
bottomext = UnitUtils.ConvertFromInternalUnits(wall.get_Parameter((BuiltInParameter.WALL_TOP_OFFSET).AsDouble(), DisplayUnitType.DUT_MILLIMETERS)
topext = UnitUtils.ConvertFromInternalUnits(wall.get_Parameter(BuiltInParameter.WALL_BASE_OFFSET).AsDouble(), DisplayUnitType.DUT_MILLIMETERS)
OUT = bottomext,topext
so where is the issue
KR
Andreas
bottomext = wall.get_Parameter(BuiltInParameter.WALL_BASE_OFFSET).AsDouble(),UnitTypeId.Feet,UnitTypeId.Millimeters
topext = wall.get_Parameter(BuiltInParameter.WALL_TOP_OFFSET).AsDouble(),UnitTypeId.Feet,UnitTypeId.Millimeters
OUT = bottomext, topext
intresting result
@Draxl_Andreas the first code will work prior Revit 2022 due to API changes
so i have to be carefull @Elie.Trad just using API 2023
@Draxl_Andreas this is the new syntax for the conversion:
b = UnitUtils.Convert(wall.get_Parameter(BuiltInParameter.WALL_BASE_OFFSET).AsDouble(), UnitTypeId.Feet, UnitTypeId.Millimeters)
t = UnitUtils.Convert(wall.get_Parameter(BuiltInParameter.WALL_TOP_OFFSET).AsDouble(), UnitTypeId.Feet, UnitTypeId.Millimeters)
Edit: you can use the ConvertFromInternalUnits method as well:
b = UnitUtils.ConvertFromInternalUnits(wall.get_Parameter(BuiltInParameter.WALL_BASE_OFFSET).AsDouble(), UnitTypeId.Millimeters)
Elie.Trad:
… the small things… so i have realy to snoop 2023 API , there are realy some diferences!
@Draxl_Andreas check the Revit API and the building coder for API changes between Revit versions:
Online Documentation for Autodesk's Revit API: 2015, 2016, 2017, 2017.1, 2018
