Setting Project Units - set Accuracy
Hi Guys,
As of API 2022, I was able to implement it as follows. But I couldn’t put the rounding.
Something related to FormatOptions.Accuracy.
Anyone know how to implement it?
Sorry for the translation.
clr.AddReference('RevitAPI')
if IN[0]:
	unit = doc.GetUnits()
	format = FormatOptions(UnitTypeId.Centimeters)
	unit.SetFormatOptions(SpecTypeId.Length,format)
	doc.SetUnits(unit)
	OUT = "length unit changed to centimeters"
	OUT = "Set IN[0] to true!"
here an example
import sys
#import Revit API
app = uiapp.Application
sdk_number = int(app.VersionNumber)
def setmeterUnit():
	if sdk_number < 2021:
		format = FormatOptions(DisplayUnitType.DUT_METERS)
		format.Accuracy = 0.01
		unit.SetFormatOptions(UnitType.UT_Length,format)
		format = FormatOptions(Autodesk.Revit.DB.UnitTypeId.Meters)
	doc.SetUnits(unit)
setmeterUnit()
Thank you! I was looking for this
