Lunzur
January 17, 2021, 7:12pm
1
Is it possible to get the category of an element with python?
I have a script where I can get all the elements from selected views or view.
Now I want to sort the elements based on their category. I am thinking on doing this with another python node.
The idea
Hamish
January 17, 2021, 7:45pm
2
The MEPover package has a node to do exactly what you show in your screenshot. You could potentially copy reference their Python code if you’re trying to avoid custom packages.
Likely you should be using a different method on the initial filtered element collector.
Several examples can be found in this repository: GitHub - Amoursol/dynamoPython: Python Modules for Dynamo
What is the error message you are getting?
Lunzur
January 18, 2021, 12:31pm
5
Thanks for the link, I will look into it to understand Python in Dynamo better.
