Python, Excel and Codeblocks
Hi, don’t know if this is what you’re looking for.
  1. You can use both code block or Python to Import Excel File
    see the image below
if you want to read specific data cell
you can refer to this post to achieve.
Reading Excel files via Python script
2) you can first set many custom functions,
and then create a new Pass Function to filter,
and execute them by the specific name using the If Loop.
see the image below.
if the input is “A” or “B”,
then func_A will be called to draw a line, or func_B will be called to draw a circle;
otherwise will draw a point at (0,0,0)
I think it may be achieved by the similar way for Custom Nodes.
the attachments are the sample file.
ExcelandPassTest.dyn (10.1 KB)
ExcelandPassTest1.xls (24.5 KB)
