Python error with new Dynamo 2.5
I am getting this error trying to run 2.3 scripts with 2.5:
Is this a problem with some libraries installation?
The graph works fine in 2.3, and Revit 2020…
thank you
reagrds
Other graphs using Data-Shape also return the same error.
Maybe I need to wait for the package updates.
thanks
Are you running this in sandbox or in Revit?
seems like this was removed in 2021:
https://www.revitapidocs.com/2020/493d203e-ef4c-b447-f979-52b22725b2ad.htm
[ObsoleteAttribute("This method is deprecated in Revit 2020 and will be removed in the next version of Revit.  Use the ImageInstance::Create() method instead")]
