Python Engine CPython3 does not exist in my python node
I need your help
I have my python script node with no engine choice. I have to specify the CPython3 engine, but I don’t know how?
Looks like you’re in an older Dynamo build. Update your host application (ie: Revit) or use a newer build of Dynamo Sandbox and you should have the option.
Hello this is Gulshan Negi
Well, it’s possible that the Python installation on your system does not include the CPython3 engine, or it may not be properly configured. You must recheck it along with all the required requirements.
Hello @jacob.small i will try to update the dynamo build
thank you for your answer
