Can someone tell me how to change to code for CPython3? Both nodes contain the same code, but gives another output. I need the same output as in Ironpython but then for Python3. So I need the type as output and not a number.
clr.AddReference('RevitAPI')
views = UnwrapElement(IN[0])
elementlist = list()
for view in views:
elementlist.append(str(view.ViewType))
OUT = elementlist
Thanks in advance.
@Lazy_BIM ,
it is more fast forwart - just view
import sys
import System
for view in views:
elementlist.append(view)
OUT = elementlist
KR
Andreas
Hi @Draxl_Andreas ,
I need exactly the same output as the IronPython gives me. I already got the views and now i need the ViewType. For example, view.Name works properly, but view.ViewType gives me a predefined number or something like that.
Offhand I think that the number is an element ID; what do you get if you use it to as such to select an element in the document?
When it’s an element ID it should be unique right? Maybe my print screen will make more clear? with the python part written in the first post.
Unique to the view type ‘floor plan’, after all items are synched with the central. Feed in a section view and see if you get something else.
FYI, here are all the numbers that you will get with each view.
hello, still too complicated for me
If that can help you
but there is node made for that, I do not understand everything
edit
found here I think numbering sticks with
Cordially
christian.stan
Thanks for all replies, I think I found my solution in the Archilab package for now.
along with import System
this works with just a single input
OUT = System.Enum.GetName(ViewType, elementlist)
Hello and thank you, I understand
import System
OUT = [System.Enum.GetName(ViewType,x.ViewType) for x in views]
Cordially
christian.stan
You are the man! I was trying to utilize the GetNames procedure to work with multiple elements.
I definitely have a lot more learning to do.
the little white pebbles helped me a lot
still in the learning phase
back to my late copy package
Have a good evening
Cordially
christian.stan
