hello everyone,
I have bunch of graphs that get instances from each view types (floor plan, section, ceiling … etc).
I also want to get the same for ‘-Disclaimer’ and ‘-Reference’. I had to use a different node for it and I’m having a hard time getting the instances for those two view types
could anyone give me a tip on which node I should use?
Thanks!
I think you’ll have to query all of your views and filter for the ViewFamilyType (or find a custom package that already does it).
Looks like it’ll require Python.
You just have to feed the
ViewType
and
ViewFamilyType
as strings.
Python Code
clr.AddReference('DSCoreNodes')
from DSCore import *
from Revit.Elements import *
clr.AddReference('System')
clr.AddReference('RevitAPI')
dataEnteringNode = IN
views = UnwrapElement(IN[0])
vType = IN[1]
fType = IN[2]
vOut = []
fOut = []
for v in views:
try:
if str(v.ViewType) == vType:
vOut.append(v)
except:
pass
try:
if str(v.LookupParameter("Type").AsValueString()) == fType:
fOut.append(v)
except:
pass
OUT = vType,vOut,fType,fOut
Thank you very much for your help! Quick question.
I’m using Ideate Explorer to check validity between values from Dynamo + Ideate Explorer.
Ideate Explorer has 185 views but either category / element are spitting out something completely different. Am I doing something wrong here? Could you also tell me whats the difference between element views and view cateogires?
Thank you!
