ViewType property issue
Hi, when I try to use ViewType property unexpected result is appearing. Can someone tell me what am I doing wrong? I expect result according enum.
views = UnwrapElement(IN[0])
# Place your code below this line
types = []
for v in views:
    types.append(str(v.ViewType))
OUT = types
here is a clue
import sys
clr.AddReference('RevitAPI')
views=UnwrapElement(IN[0])
col=[]
col1=[]
for v in views:
    c=v.GetType()
    c1=v.Name
    col.append(c.Name)
    col1.append(c1)
OUT = col,col1
Cordially
christian.stan
Also, Clockwork has View.Type node that works correctly. You may can look at that to see the issue with your code.
Your code is correct.
It’s a CPython3/Pythonnet 2.5.x issue, .NET enums are automatically converted to Python int
A temporary fix with CPython3/PythonNet 2.x
import sys
import System
dictViewType = dict(zip(System.Enum.GetValues(ViewType), System.Enum.GetNames(ViewType)))
types = []
for v in views:
    types.append(dictViewType.get(v.ViewType))
OUT = types
result in comparison with the as yet unofficial IronPython3 engine
Hello, I know you are a magician :wink: but how do you do under IronPython 3 without adding to the clr (RevitAPI)
is it already included?
Cordially
christian.stan
to read some properties (like Enum), loading .NET assemblies is not necessarily necessary
@c.poupin, thank you.
Where can I get IronPython3 executor?
It’s a work in progress package
You could also use System.Enum.GetName(ViewType, v.ViewType) after filtering for nulls
