Python code error KeyError:<Autodsk.Revit.DB.ForgeTypeId
How should I solve the above problem?
your input ā€œunittoconvertā€ seems not to be a string, but a forgetype. you can therefore not find that as a key in your dictionary.
see if OUT=type(unittoconvert) returns a string.
if not, you could try to convert it to a string and then query your dictionary.
Try using the UnitUtils.Convert() method like this:
  • Revit >= 2022
    newvalue = UnitUtils.Convert(oldvalue, UnitTypeId.FeetFractionalInches, UnitTypeId.Meters)
  • Revit < 2022
    newvalue = UnitUtils.Convert(oldvalue, DisplayUnitType.DUT_FRACTIONAL_INCHES, DisplayUnitType.DUT_METERS)
So in your case something like
OUT = UnitUtils.Convert(1.0, UnitTypeId.Feet, IN[0])
[Edit] TIL there’s a unit called a slug - lol
#imports the Revit API
clr.AddReference('RevitAPI')
#sets the distance to convert as input 0
originalUnit = IN[0]
unitToConvert = IN[1]
#builds a hard coded list of dictionary values for the conversion factors
conversionToFeet = {
        "DUT_METERS":1/3.28084,
        "DUT_METERS_CENTIMETERS": 1/3.28084,
        "DUT_MILLIMETERS" : 304.8,
        "DUT_CENTIMETERS" : 30.48,
        "DUT_DECIMAL_FEET" : 1,
        "DUT_FEET_FRACTIONAL_INCHES": 1,
        "DUT_DECIMAL_INCHES" : 1/12.0,
        "DUT_FRACTIONAL_INCHES" : 1/12.0
originalUnitInFeet = 1/conversionToFeet[originalUnit]
convertedUnit = originalUnitInFeet * conversionToFeet[unitToConvert]
convertedUnit = round(convertedUnit,10)
# return the converted length value
Is that right?
but it But if you write the code like this
An error appears that the old value is not defined
line 30
NameError:name ā€˜oldvalue’ is not defined
