I can't find the str id?
#  Import RevitAPI
clr.AddReference("RevitAPI")
from Autodesk.Revit.Creation import *
FirstPoint = IN[0]
SecondPoint = IN[1]
level = UnwrapElement(IN[2])
pipeType = UnwrapElement(IN[3])
systemType = UnwrapElement(IN[4])
outpipes = []
#  create transaction
for i,x in enumerate(FirstPoint):
    pipe = Autodesk.Revit.DB.Plumbing.Pipe.Create(doc, systemType.Id,    pipeType.Id, level.Id, FirstPoint[i].ToXyz(), SecondPoint[i].ToXyz())
    outpipes.append(pipe   )
OUT = outpipes
Warning: IronPythonEvaluator.EvaluateIronPythonScript fail。
File “”, line 37, in
AttributeError: ‘List[object]’ object has no attribute ‘Id’
How can I modify the script ?
Thank you for response. I provide the program ,autocad file, and the capture picture. I’m a beginner for dynamo. So many thanks for you.
And also feed python with ONE family type for both pipeSystemType and pipeType (IN3 & IN4)
How can I modify ?
