Putting Sections on Alignment
Hi all.
I am currently having hard time on setting my earthwork volume calculation project and trying to use 2D sectional drawings to come out with 3D model.
What Im trying to do is:
  1. Set block of cross-sectional drawings to upright towards z axis.
  2. Place them on the established cross-section reference alignment line.
  3. Specify a separate layer for each cross-section you place (for ease of surface work)
  4. Attach them on the end line or end point TX reference.
  5. Relocate them to the appropriate FH elevation.
Sections:
Alignments:
Anyone can help me on this? i would be really appreciated if you could help me with the solution.
Hi @SM_LSJ .
Just wondering, what is preventing you from creating a corridor and attaching assemblies to it following the selection of an alignment and a profile ? it would be less complicated than doing it this way.
Otherwise, if you can explain the issue that you have with the earthworks, so people here can solve the issue right away and it could be done directly on C3D rather than trying to solve it with dynamo.
