Hi I’m trying to publish a package locally that ill then put on the server that copies to everyone else. Currently its not publishing with the right name and only 2 of the 7 or something nodes are showing
Tried again and now its under error
Hey @vanman
3 Questions to start ![]()
Dynamo Version?
How many nodes are missing?
Any other package dependencies?
I would start with checking for Dependencies and removing them one-by-one (if they exist) to find out where the bottleneck is.
Looks like you have been here having issues with Clockwork before ![]()
Ewan! Hello. I added an error I found which I think is coming from the package
2.16
10 nodes not working
Clockwork!
haha yeah I have! there was a buggy node I had to get rid of in it. But I’m not sure if thats the case now
Depends on Clockwork doesn’t it?
Where are you running your packages from?
Local Machine, Local Server, OneDrive, Google Drive, Git?
Eliminated network issues?
I have found in past that having all packages pathed locally for publishing purposes only really helps with stability.
They are run from local drives. Theres a windows copy script that runs on everyones computer to mimic whats on the server.
Can you post that JSON file? And the one for the package, from a previous version perhaps?
I dont know why its calling up those local files. Theres no Json there. There was heaps of them
Ah if you have dependencies in your package I’d get rid of those ASAP. They cause major issues. E.g. using Rhythm inside your own package.
The Bakery package is a good example of why not to do this if you can avoid it.
Yes @GavinNicholls is on the money, keep your package self sufficient.
Reduces the chance of these errors exponentially, and makes versioning easier as well.
You should be able to extract most package node functions (if not Zero-Touch, those are a bit trickier and need to be recreated) to be native in your dyn or as a supporting dyf, keeping coding credits of course. ![]()
Always happy to help if required. ![]()
Thanks guys appreciate it. Spent so much time getting help documents and all sorts ready to release dynamo then 2023.1 or something upgrades to 2.16 dynamo and now Rhythm isnt working(who knows what else). Managed to get my package working just using the core nodes ive made from help here. But any chance you know why Rhythm isnt working? Loads the dyf files but not nodes which are in a dll or something? Nothing is blocked. So close to having everything sorted then I can just get jammed up for hour/days trying to solve one thing ![]()
I was using 2 back from the latest but im about to head back to the office and install the latest
ok so signing in and out twice seem to fix the issue of it copying properly or something. Thanks for all the help! Better hop on someone else computer and cross my fingers
