Using the Package Prorubim, but it seems not to work correctly.
The + node does not read the inputs, even though the watch node gives numbers, and I get a NULL
I know it only support in-built dynamo input nodes (except Code Blocks)…
Any ideas?
Can you try running both of the numbers through an Object.Type node and post the results? Any chance one of the numbers is a string for instance?
@jostein_olsen,
Thanks!
The problem was in the Formula “Abs(x)”, with the standard “Math.Abs” it works fine…
