Property Set Data - Corridor Identity: handles are wrong
Hi all,
There is a bug in the Property Set nodes when reading the ‘Corridor Identity’ Property Set Data of Solids extracted from a Corridor. The ‘Corridor Identity’ data is new as of Civil 2023.
The ‘handle’ issue was also reported here:
https://forum.dynamobim.com/t/reading-property-value-wrong/48968
The fix there was to change the name of the custom ‘handle’ property.
But with ‘Corridor Identity’ data, this is not possible. This means that it is impossible to get the values of the ‘AssemblyHandle’, ‘CorridorHandle’, and so on, of extracted solids.
For now, you need to read the Corridor Identity data with Python to get the correct values.
Greetings,
Donny
