Property Lines aren’t listed…
Is there a way to make the user only select property lines in Dynamo?
Pretty sure I can do it easily in Python but I’m interested to see if I can do it in Dynamo.
Site - Property Lines
or Site - Property Line Segments
depending on the need.
If it has to be said first, it isn’t obvious and could be placed better, but that’s a BIG change across a lot of stuff that’d create more pain than benefit as it’d break a LOT of existing stuff in the API if it were changed there, and Dynamo for Revit deviating from the API makes users growing into more capable developers harder if it were just remapped, so it’s likely to stay…
But now you know, so that’s good.
